HackadayPrize Finalists
Made it to the final for Wildcard category. Thanks everyone for support!!
Release v0.6
Just released on GitHub a new firmware: release v0.6. This is mostly a bug fix release mostly related to Bluetooth controllers timing issues. BlueRetro community is growing slowly but I already get very useful feedback to help fix issues!
Bluetooth
- Fix PS3 config timing issue
- Fix Generic HID config timing issue
- Improve TX Q handling
- Fix early PS4 pairing issue (FCCID AK8CUHZCT2) (Thanks @sofakng !)
- Boot SW can now be used to Disconnect all devices (Not supported by Xbox One, those require holding power button)
- Fix SW pairing regression introduce by PS4 fix.
Wired
- GC rumble is enabled via controller accessory config just like Rumble Pak & Jump Pack. (Default off)
- Fix GC rumble being set on by any bits in console report. (Thanks @BBsan !)
Adapter
- Error LED is clear at boot (indicating FW ok). Any SD card or BT radio error will set it on.
- System override config truly take precedence over auto detect mode.
- Fix stack overflow in feedback task.
Roadmap
I shared my google spreadsheet I use as a roadmap so you can have an idea on what I'm working on and on the order I will do them.
PCBs
I think the PCBs rabbit hole finally came to a closure. I received v1.1 DevKit yesterday and should be able to build and test them sometime this week. Also production of the adapter cable PCBs is done, just waiting to receive them sometime next week.
![](https://cdn.hackaday.io/images/585071599658969127.jpg)
