Spend a lot of time this weekend building all the different cable adapter.
![](https://cdn.hackaday.io/images/8947501600624944544.jpg)
I think they take me around 20 min / 30 min to build each. Really happy with how the PCBs turnout. The gates size is small but still easy to manage. I think building the original Saturn cable prototype took me around an hour and 3 hours to troubleshoot. Those boards are a real time saver and they look really nice.
![](https://cdn.hackaday.io/images/344331600624237850.jpg)
NES, SNES & Saturn
I re-validated FC/NES, SNES & Saturn cables in all modes supported and everything works as with the prototype cables.
![](https://cdn.hackaday.io/images/7235611600625108499.jpg)
![](https://cdn.hackaday.io/images/7991621600625157538.jpg)
![](https://cdn.hackaday.io/images/9772811600625187586.jpg)
JVS
I found an issue in the JVS 5V step up circuit. I connected the feedback pin to GND rather than the power output! I will correct the Kicad files but will not reorder new boards. I'll just fix the boards I got by cutting the trace.
Cables for upcoming new system support
I was originally planning to built cables only for my short term need for MegaDrive/Genesis, PSX/PS2, & NeoGeo software development up until v1.0. But while I was at it I decided to do a few extra ones including PC Engine, CD-i, 3DO, PC-FX & (S)NES classic systems (Wii ext.).
Doing so allowed me to validate that the detection code works for all of those systems flawlessly. It was also a good test to validate that each system can power up BlueRetro. I actually found out that PSX & PSOne system does not provide enough power over the 3.3v output to power BlueRetro! PS2 got no issue, however. Since I'm using a low voltage drop regulator (for N64 3.3v only) the voltage input range max out at 6V. PSX/PSOne second power output is ~8V.
To fix this problem I will redesign the passthrough cable PCB to include an LDO on the bottom side to convert 8V to 5V. This will be only populated on the PSX/PS2 cables.
![](https://cdn.hackaday.io/images/6048391600626139976.jpg)
![](https://cdn.hackaday.io/images/6550181600626162199.jpg)
![](https://cdn.hackaday.io/images/404591600626191904.jpg)
![](https://cdn.hackaday.io/images/8199431600626212545.jpg)
![](https://cdn.hackaday.io/images/2190881600626237981.jpg)
![](https://cdn.hackaday.io/images/1433611600626262555.jpg)
![](https://cdn.hackaday.io/images/8515371600626583168.jpg)
![](https://cdn.hackaday.io/images/2459861600626600958.jpg)
PC-FX cable
![](https://cdn.hackaday.io/images/2517971600626900470.jpg)
![](https://cdn.hackaday.io/images/6470171600626930043.jpg)
![](https://cdn.hackaday.io/images/3006991600626950524.jpg)
PCE / CD-i Mini-DIN 8
I used part of my Saturn extension cables to build my own Mini-DIN 8 cables.
![](https://cdn.hackaday.io/images/4462311600627055469.jpg)
![](https://cdn.hackaday.io/images/4950701600627076969.jpg)
![](https://cdn.hackaday.io/images/7773071600627093365.jpg)
