Getting Started
A project log for Sand/Powder/Clay Printing
Experiments with Sand, Powder and Clay Printing + Firing in a Furnace
dominik-meffertDominik Meffert 04/17/2020 at 17:570 Comments
I bought some parts for getting started. The parts on the left should later become the clay extruder and the parts on the right should later become the sand extruder.
A few parts are still missing like 3D printed parts to hold everything together.
I found a way to use the sand/powder extruder in a vertical orientation to save a lot of space. The sand exits the extruder through the side port of the T fitting only when the drill inside is moving. I will also add a 3D printed nozzle to the sand outlet to bring the sand as close to the clay nozzle as possible.
