HOW TO CONTROL SPEED OR TORQUE OF YOUR BRUSHLESS MOTOR WITH ARDUINO USING SOLO (CLOSED-LOOP)
A project log for SOLO, A Universal Motor Controller
SOLO is a Motor Controller designed to easily run most types of electrical motors, DC, BLDC, PMSM and ACIM. it's easy to use and versatile.
miladmilad 04/20/2020 at 12:390 Comments
In this tutorial you will see how to control the Torque or Speed of your Brushless DC motor using SOLO and Arduino in closed-loop sensor-less manner . In this tutorial Arduino acts just like a commander and sends some PWM pulses to increase or decrease the Speed/Torque. If you like you can use just a potentiometer instead of Arduino.
The full Article:
https://www.solomotorcontroller.com/how-to-control-speed-or-torque-of-your-brushless-motor-with-arduino-using-solo-closed-loop/
