Laser kerf test
A project log for COSV - Cam Open Source Ventilator
Roller cam based portable BVM ventilator.
daren-schwenkeDaren Schwenke 06/09/2020 at 21:590 Comments
Made a test jig for determining the proper setting for laser kerf.
You stick a bearing in the holes until it fits, and the number above that hole is your laser kerf.  Similarly the slots below are for testing the edge joint kerf.
