Day 1
A project log for AMD 2900 Chipset Research
Exploring the 2900 family bit slice chip set.
rey-mortaRey Morta 03/24/2020 at 18:500 Comments
Wiring up the AM2901 to the Arduino Mega and getting a responce.  To start out I have only wired access to 2 of the address lines for the registers.  The output port from the AM2901B was held enabled.
Wiring
MegaAM2901
2,3
4,5
6
7
A0,A1
B0,B1
Clock
Carry in
14,15,16,17Data Out (Y)
30,31,32ALU Source
33,34,35ALU Function
36,37,38ALU Desitnation
50,51,52,53Data In (F)
RAM0 to RAM3
Q 0 to Q 3
Held HighA2, A3
B2, B3
Held LowF output enable.
Bit order for ports do not follow pin order
