4 Color Gray
A project log for ePaper fridge magnet
Put your images on a SD card and display it on your fridge
waldo-wolmaransWaldo Wolmarans • 11/10/2020 at 11:38•0 Comments
I'm updating the source code to display 4 color gray images using the standard b/w 2.7 inch e-paper screens .  The black and red screens also can display gray scale but the gray is very light.
For now it will be a separate branch on git . But I plan to make it a config option in the SETUP.TXT file.
Here is a couple samples.
