If you want my body
A project log for VISP - Ventilator Inline Sensor Package
Bidirectional flow (volume), pressure, and temperature sensing in a single inexpensive I2C/SPI package.
Daren SchwenkeDaren Schwenke 03/30/2020 at 07:590 Comments
The body and cover for the flow sensor are done.
You can use either the BMP280 or BMP388 for any sensor position now.  Both footprints are on the board.
The recess in the cover is to house the optional 128x32 OLED.
https://github.com/Arcus-3d/cosv/blob/master/hardware/rendered/FFF/flow_sensor_for_pcb.stl
https://github.com/Arcus-3d/cosv/blob/master/hardware/rendered/FFF/flow_sensor_cover.stl
