I built the frame script from the cranks out; there are several systems which are used to communicate frame dimensions so this is just one approach. As of V6 you can expect a considerable amount of trial and error but the key component locations are modeled.
![](https://cdn.hackaday.io/images/2263161585520619471.png)
Imputing a sample table like:
![](https://cdn.hackaday.io/images/9241861585521551502.png)
You get a result of:
![](https://cdn.hackaday.io/images/5375671585521582177.png)
Forget the extra tubes, think of them as boundaries.
There is a pretty big error right now, this system relies on fork length to drive the top tube length. But that's the status of the builder so far, working on V7 now.
