Glitches, and how to get rid of them -Part II like a pro!
A project log for Digi:Arka
Dirt-cheap Vaus paddle clone for MSX - Now supports Standard Paddles too.
danjovicdanjovic 04/02/2020 at 01:310 Comments
I have studied the nature of the glitch for this particular device and verified the following fact:
then I have added another facts:
Then just as I was considering the last fact.....
The solution slapped me in the face!
"CLEAR PIN CHANGE INTERRUPTS AT THE END OF EXTERNAL INTERRUPT SERVICE"
And that was done...
// External Interrupt driven by Clock pin (6)
ISR(INT0_vect) {
  // output a new bit
  if (shiftRegister & (1 << MSBIT)) {
    pinMode(DATA, INPUT_PULLUP);
  } else {
    digitalWrite(DATA, LOW);
    pinMode(DATA, OUTPUT);
  // pre-shift next bit
  shiftRegister <<= 1;
  GIFR |= (1<<PCIF );   // <- De-glitch in a single instruction!
 The result  can be seen below. Glitches still appear but they do not cause any harm !
