Merged *next branch* into master
A project log for ddPrint - Adding Process control to FDM printers
ddprint: a fdm 3d printer firmware and printing system
erwin-riegerErwin Rieger 03/31/2021 at 21:590 Comments
Merged *next branch* into master with the following changes:
* Feed forward temp control (*PID hinting*, *guided PID*) :-o
  AutoTemp algorithm: set new temperature some time before the new flowrate demand,
  using the information from the material profile.
* Added a experimental gcode (M901) for part strength (along with new *workingpoint*
  command line parameter) :-o
* Asymmetric PID temperature control: switch between different PID control sets for
  heating (fast) and cooling (a slower PID set to avoid temperature underruns).
* Deflate/zip data downloaded to printer to increase download speed over usb-serial.
  Using python's zlib on the host and uzlib (https://github.com/pfalcon/uzlib) on
  the firmware side.
* Added a second step to material profile measurement (measuretempflowratecurve2):
  Measure hotend performance while doing a real print, in addition to the *into-the-air*
  extrusion measurement.
* Some smaller improvements:
   + Moved printer-, nozzle- and material-profiles into their own
     repository (https://github.com/ErwinRieger/ddprint-profiles).
   + Show print time in CLI and terminal UI (TUI).
   + Show the number of *under-temperature* and *under-grip* warnings in TUI.
   + Added a *printlog* to ddprintui.py: log information about the current
     printjob (gcode info, timestamp, printing time, slicersettings).
   + Added some tools and scripts (plot_mat_profile, ddtool, wrapperscripts).
   + Removed usage of eeprom, configuration now stored on mass storage device (sdcard, usb).
   + And many more...
