Pinout
A project log for SAAB 9-5 Window Control Module Modifications
Exploring what can be done with the SAAB 9-5 (1999) window control module
saabmanSaabman 04/23/2020 at 12:410 Comments
After scouring through the SAAB Workshop Information System I finally found the wiring diagram for the Windows. Funnily enough not located in the wiring diagram section but under
  1. NC
  2. Rear Right 1
  3. NC
  4. Illumination in
  5. Rear Right 2
  6. Front Right 1
  7. Front Right 2
  8. Ground
  9. Rear Window lock (12V active 0V locked)
  10. NC
  11. 12V in
  12. 12V in
  13. NC
  14. NC
  15. NC
  16. Rear Left 1
  17. Rear Left 2
  18. Front Right 2
  19. Front Right 1
