Hackaday.io Hackaday.io
Sign up Log in
Headless Guitar Bridge Controled via App
An app controlled guitar bridge for headless electric guitars.
the-meiquerThe Meiquer
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
361
3
4
4
Team (1)
  • the-meiquerThe Meiquer
Join this project's team
MISC
ongoing project
GUITAR ESP32 MusicalInstrument headlessguitar
This project was created on 04/07/2020 and last updated 6 years ago.
Description
This is a guitar bridge for headless electric guitars. I used Blynk app to tune up and tune down the strings and an Esp32 as the brain. Six gear motors and thre h-bridges to control the motors.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
The Meiquer wrote 04/08/2020 at 17:34 • point
You're right. The motors that I'm using are not the best choice. They work with 6V geared down to 30RPM. I think a 12V with 60RPM will work better. I bought them to use on another project...
The Meiquer wrote 04/08/2020 at 17:57 • point
I'll post some pictures of the anchor points
Dan Maloney wrote 04/08/2020 at 17:14 • point
I wouldn't have thought a tiny motor like that could be geared down enough to tension guitar strings. Interested in what the anchor points look like on the other end of the neck.
Interactive Design Experience
Project Owner Contributor
Remote-Controlled Car with Real-Time Video Stream
zalalyoussefzalal.youssef
Zadaniem urządzenia jest przekładanie znormalizowanych palet transportowych. Urządzenie sterowane bezprzewodowo za pomocą sieci Bluetooth.
Remote Control Forklift
maurycycichockimaurycy.cichocki
Use ESP 32 as a proxy to send External Control Protocol commands to your Roku TV.
ESP32 Based Remote Control for Roku TV
elshnkhllELSHNKHLL
Mo Control is an app for controlling Moti Smart Motors to make it easier to build robots.
Mo Control
nicholas-stedmanNicholas Stedman
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Headless Guitar Bridge Controled via App", please tell us the reason.
Send message
Remove Member
