Piezo orientation
A project log for DIY mesh conversion of a simple drum set
Pad-to-mesh conversion of an electronic drum set (Alesis DM6) using low cost toy drums
evgenyEvgeny 04/22/2020 at 17:390 Comments
Apparently, you don't just glue piezo as you wish - the ceramic should be facing the mesh:
Placing it upside down will add >5ms delay and will remove that crucial first peak that is most likely being analyzed by pulse processor.
now I need to get rid of this mesh hi freq vibration.
So now I need to flip all the sensors and to start analyzing what happens to the signal inside the analogical debris of the drum module.
