Motherboard Diagnosis - what caused the issues?
A project log for ITXBox, Putting a Computer in an XBOX Shell
My variation on the project of putting a computer in an XBOX Shell
ryan-walmsleyRyan Walmsley 04/26/2020 at 10:110 Comments
So, as mentioned in the previous post I installed the system on another motherboard I had while the one I wanted to use I had to send back because of there being no output from the iGPU.
I had tried two different CPUs, RAM, all 3 display outputs with no success. The rest was working fine as a discrete GPU worked. I also know all the CPUs worked from where I was installing and testing it fine .
I sent the motherboard away for RMA and they got it and showed it working fine. What the heck? So I arranged for it back and it didn't work still.
But when I tried the new Pico PSU, I got and it started working. But the other power supply worked with the other motherboard so what's going on?
I then tested 2 other power supplies with success and the original didn't work again and furthered on with investigation.
So what caused it?
The most likely explanation I have right now is that it turns out the power supply I was using has no -12v rail. Now there's no reason I know of that causes the iGPU to not work without a -12v rail.
The negative 12v rail is more a legacy thing from where some ISA cards used them and it was sometimes used to either generate +24v for some devices or the negative rail for Serial (altough even this is rare as some ICs that did the logic conversion have a built in negative rail generators).
All I can think is that whatever circuit this motherboard has, somehow uses the -12v rail I suspect just enough to activate whatever circuit its using and doesn't even draw a lot of power.
However for now as I'm using a pico psu then this isn't a major issue now. But was an interesting issue.
