I also tested two TMP117N in same thermostat to show if their uniformity. As you see most error was just 19/20 LSB(0.15℃). Amazing!
A thermometer result with a resolution of 0.0078°C and
an accuracy of up to ±0.1°C across the temperature
range of -20°C to 50°C.
