SPLD fault finding
A project log for PZ1 6502 laptop
I am building a laptop with a W65C02, lots of memory, SID-sound, decent graphics and a filesystem.
adamklotblixtadam.klotblixt 08/10/2021 at 05:380 Comments
It took far too much time to track down the problem with programming the ATF22LV10C SPLDs.
I started out with the afterburner programmer trying to get the ATF750LVC to program, but failed. The chips are seemingly not compatible enough with ATF750C.
After getting the smaller ATF22LV10C I tried using them instead. The software claimed programming and verifying worked but the chips did NOT work properly in my testbench. I spent a lot of time searching for what was wrong. In the end I succeeded when recompiling all the code for the programmer from the main branch, that lacks support for ATF750C. Oh well, it sometimes takes a long time to travel small distances.
I am very happy to finally being able to program SPLDs, it makes the project so much easier to do properly.
