Type 0 is NULL/Error and detected from the three LSB.
But the remaining MSB are not checked...
So if the MSB are not cleared, this could lead to yet another type, 8-byte aligned. What could it be ?
A project log for Aligned Strings format
Developing a more flexible pointer and structure format that keeps some POSIX compatibility without the hassles
