KiCAD6. M10NC01-10 was designed using/ CNC_Breakout_Nucleo64 exact design and ported to M10CUBE platform. Is using GRBLHAL software https://github.com/grblHAL
All modules from version 10 and later are sharing the new 90x90mm PCB.
Sent for PCB fabrication in JLCPCB.
![](https://cdn.hackaday.io/images/6095861641823059814.jpg)
![](https://cdn.hackaday.io/images/7759431641823075268.jpg)
https://drive.google.com/file/d/1lqcJAB9dWVi5FL99OL5zKJ2o9BPOuXyq/view?usp=sharing
