FINAL PCBs
A project log for M10CUBE
M10CUBE (M10 in short) is a modular controller box with cube dimensions 10x10x10cm. Raspberry bus will be used for the first incarnation.
vasilis-vorriasVASILIS VORRIAS 10/02/2020 at 10:350 Comments
3/09/2020
At last after many days of redesigning and trimming ready to send for PCB fabrication (hoping everything is correct.) a complete set of M10CUBE modules.
New naming convention is introduced
M10PR01-01 (Prototype board and can be used as the bottom PCB on CPU frame)
M10PS01-01 (PSU module)
M10DX01-01 (8xDigital Inputs + 8xDigital Transistor Outputs)
M10DO01-01 (8xRelais Outputs 16A)
M10SE01-01 (Sensor board + ESP32 + RS485, +LoRa + GPS)
All design files can be found on GitLAB
https://gitlab.com/m10cube/m10
