Testing connectors
A project log for Wild Card - Fire Fly UVC Air Tunnel, Air Sanitizer
Fire Fly UVC Air Tunnel is an all 3D printed modular design, utilizing UVC Lamps and 120mm fans for silent and rapid air sanitizing.
Josh StarnesJosh Starnes 06/11/2020 at 07:100 Comments
So each module needs power control, the connectors pass through the core of the feet. The format is a 12v CCTV style connector. Here you see we print a sliced chunk of the model checking fitment without waiting hours for entire pieces to print.
