New tray and body slightly larger
A project log for Fire Fly UVC Mini 3W Sanitizer / Curing Lamp
Fire Fly Mini UV Handheld USB Powered Disinfection and Rapid UV curing lamp combines small form factor, cost efficiency and 3d printing.
Josh StarnesJosh Starnes 07/08/2020 at 02:130 Comments
The body is 1-2 mm thicker now and there are cut outs for the capacitors to have room. The tray is now deeper to allow extra clearance from the solder joints and pins on the bottom of the PCB.
