Measured for a custom 3d printed ring
A project log for Field Ready-TRIO UV 365-395nm Curing Light
3 watt White LED, 9 watts 365nm UV and 9 watts 395nm UV. All in one tool built for Field Ready use.
josh-starnesJosh Starnes 07/08/2020 at 01:330 Comments
This ring holds to two case halves together and also holds the reflector in place in the tip of the flashlight. Here we are measuring for it.
