We needed to move controlled
A project log for DP Ventilator
Battle against Covid-19
dannyvandenheuveldannyvandenheuvel 05/24/2020 at 10:090 Comments
To move controlled in both directions Up and Down we used springs, this way we are fully guiding the press system on the amu-bag.
We take the cover of the box and made some things on it.
Every piece has been made to easily be removable. The motor Knob can be used when the machine is powered off to clamping the abu-bag between the two squeezers.
The spring system can be easily removed
