Lua Script
when the Lua script is started on the camera,
it activates the cameras "half press" to focus and AF lock the camera.
this half press is "held" throughout the whole sequence
to keep the focus from changing between exposures.
the script then waits for the Arduino to pulse the USB "HIGH",
which is received as a trigger event from CHDK.
the script initiates the exposure by having the camera go "full press" and back to "half press"
half press is not released until the end the exposure sequence.
the camera must be set to fixed exposure(s), to avoid the picture changing,
with varying light conditions as it pans around.
blinking the LED is done by poking directly to the Cameras hardware registers,
specific to the camera type. for the 110HS its 0xC0220164 and 0xC022C028
I forget the details now. but I believe I based my Lua script on the HDR Fast Shooter script
adding a few things, menus, detection of finished exposure, and of-course the LED blink function.
--s 96
@title HDR Panorama Robot
@param m Number of HDR steps +/-
@default m 0
@values m S -S+ --S++ ---S+++
@param t tV step size
@default t 2
@values t 0 0.5 1 1.5 2 2.5 3
@param d shot delay 5
@default d 0
@param b blink delay 3
@default b 0
-- release AF lock on exit
function restore()
set_aflock(0)
end
function blink_led()
status = poke(0xC0220164, 0x46, 1) --Turn LED ON
status = poke(0xC022C028, 0x46, 1) --Turn LED ON
sleep(( b*100))
status = poke(0xC0220164, 0x44, 1) --Turn LED OFF
status = poke(0xC022C028, 0x44, 1) --Turn LED OFF
end
-- setup
--n=m
n=((m*2)+1)
s=(t*(96/2))
set_console_layout(10, 0, 40, 14)
props=require("propcase")
propset=get_propset()
pTV=props.TV
if( propset > 3) then pTV2=props.TV2 end
print("** PANO BOT SCRIPT ***")
print("**** MAKE SURE *******")
print("**********************")
print("* NOT CONTIOUS SHOOT *")
-- focus and get exposure
press("shoot_half")
repeat
sleep(50)
until get_shooting() == true
set_aflock(1)
-- tv96val=get_tv96()-(n*(s/2))
tv96val=(get_tv96()-((n-1)*(s/2))) --
origtvval=tv96val -- reset original TV start Value
repeat
if ((is_pressed("remote")) or (is_pressed("video"))) then
tv96val=origtvval
ecnt=get_exp_count()
-- take the shots as fast as possible
for i=1, n, 1 do
print("step=", i, "tv96=", tv96val)
set_prop(pTV,tv96val)
if( propset > 3) then set_prop(pTV2,tv96val) end
press("shoot_full_only")
repeat
sleep(20)
until(get_exp_count()~=ecnt)
release("shoot_full_only")
tv96val = tv96val+s
end
repeat
sleep(20)
sleep((d*100))
blink_led()
end
until ( false )
restore()
