Drone Weight In
A project log for Open Sky Anchor WiFi Drone Brings The GIG
Mission "Wifi" Impossible > Bring Long Range 5G and 2.4 G WiFi Backed By A 1 Gigabit Fiber To The East Brainerd EF-3 Tornado Disaster area.
josh-starnesJosh Starnes 08/25/2020 at 19:200 Comments
weight in 10 pounds 4 ounces. At 12.6 volts DJI estimates 600 gram thrust per motor, however we have upped the voltage to 15 volts even, but still below the 17 volts recommended maximum for the ESC / Motor combination tuned E300 system. I am considering swapping to smaller heatsinks without fans to lose around a pound since there are 8 of them.  I have smaller and longer ones that would be only 4 and no doubt a weight decrease.  The upper level anti vibration I added could be eliminated if needed to maybe lose another half pound or so, but that’s a last resort.
