BOM for the 1st ( of three) 500 watt power supplies
A project log for Open Sky Anchor WiFi Drone Brings The GIG
Mission "Wifi" Impossible > Bring Long Range 5G and 2.4 G WiFi Backed By A 1 Gigabit Fiber To The East Brainerd EF-3 Tornado Disaster area.
josh-starnesJosh Starnes 09/01/2020 at 20:300 Comments
‎941-1792-ND‎ ‎PACSR12042S‎ AC/DC CONVERTER 12V 504W 1Immediate 187.87000$187.87
2 ‎1189-2033-ND‎ ‎450VXH220MEFCSN25X35‎ CAP ALUM 220UF 20% 450V SNAP 3Immediate 3.86000$11.58
3 ‎490-9555-1-ND‎ ‎DE2E3KY222MN2AM01F‎ CAP CER 2200PF 250VAC RADIAL 1Immediate 0.46000$0.46
4 ‎P122323CT-ND‎ ‎EEU-FS1C821LB‎ CAP ALUM 820UF 20% 16V THRU HOLE 6Immediate 0.66000$3.96
5 ‎490-9555-1-ND‎ ‎DE2E3KY222MN2AM01F‎ CAP CER 2200PF 250VAC RADIAL 1Immediate 0.46000$0.46
6 ‎1189-2033-ND‎ ‎450VXH220MEFCSN25X35‎ CAP ALUM 220UF 20% 450V SNAP 1Immediate 3.86000$3.86
7 ‎490-9531-1-ND‎ ‎DE2B3KY101KN2AM01F‎ CAP CER 100PF 250VAC RADIAL 3Immediate 0.41000$1.23
8 ‎490-9561-1-ND‎ ‎DE2E3KY472MN2AM01F‎ CAP CER 4700PF 250VAC RADIAL 10Immediate 0.39600$3.96
9 ‎1572-1784-ND‎ ‎MPX104K305D‎ CAP FILM 0.1UF 10% 305VAC RAD 2Immediate 0.41000$0.82
10 ‎P14783-ND‎ ‎ECQ-UAAF474M‎ CAP FILM 0.47UF 20% 275VAC RAD 3Immediate 0.64000$1.92
11 ‎490-9463-ND‎ ‎DE2E3KY152MA3BM02F‎ CAP CER 1500PF 250VAC RADIAL 2Immediate 0.45000$0.90
12 ‎RNV14FAL820KCT-ND‎ ‎RNV14FAL820K‎ RES MF HV .25W 820K OHM 1% AXIAL 3Immediate 0.26000$0.78
13 ‎553-3963-ND‎ ‎PH9455.705NL‎ CMC 6.5MH 9A 2LN 6.4 KOHM TH 2Immediate 7.61000$15.22
