Building a weather station for my local glider club
Starting off with a Raspbian Buster (Desktop) install:
SSH into the system.
As per any new install of raspbian, be sure to
With this we will have the baseline pi setup, with a 64 bit kernel. You can validate by using uname -a, you should see "aarch64" in the string.
We want a few extra packages.
Since this is a remote weather station, Mosh will allow for more reliable communications over a flaky network.
Docker will allow easier operation of Weewx. Compose lets us use a single file to configure the deployment.
View all 4 instructions
bobricius
Ian Maday
Inderpreet Singh
fr1sk
Yes, delete it Cancel
You are about to report the project "Gliderport Weather Monitor", please tell us the reason.
