Initial Rough Ideas
A project log for Oreon Exosuit
An exoskeleton that combines a rigid steel frame with soft robotics and servo motors.
lizarddragon1054lizarddragon1054 06/28/2020 at 05:090 Comments
The first prototype will be for one arm, including a steel frame for the bicep and forearm area. The goal of it will be to:
1. figure out ways to have a good range of movement for the arm (not including shoulder)
2. optimize size and placement of the pneumatic muscles
3.  get a good idea of what the hand modification/enhancement will look like, from a design and usability standpoint (if an "extra" larger hand is added past the actual normal hand, it will vastly increase the strength requirements for the bicep-forearm muscles)
