Earth Funnel Quick and Dirty Prototype
A project log for 2020 HDP Dream Team: CalEarth
The 2020 HDP Dream Teams are participating in a two month engineering sprint to address their nonprofit partner. Follow their journey here.
jason-knightJason Knight 07/30/2020 at 21:011 Comment
This week the goal was to make a quick and dirty prototype of the Earth funnel. There are n Fablabs available and not enough time to wait for a commercial laser cut service. So I used a projector, to project the net on to a piece of plywood. I calibrated the scale with a caliper and traced over the net manually then cut it out using a jig saw.
I then clamped the sheets in to a cone profile and used a rivet gun to pop them in place.
Finally I ducttaped the section on to an old plant pot which was congenitally the same diameter and length as the tube we intended to use. A handle cut from an old plastic oil bottle was taped in place.
Note: the purpose of this prototype is to test the mechanical feasibility of using the tool to fill the bags, not the build process or final materials.
Giovanni wrote 08/03/2020 at 03:59 point
Resourcefulness at its best!
