Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Solar MPP tracker
Companion project for 4004
JanJan
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 1
Public Chat
1
5
3
Team (2)
  • JanJan
  • EntunassaEntunassa
Join this project's team
hardware
researching project
MPPT solar
This project was created on 07/01/2020 and last updated 9 months ago.
Project Logs
Collapse
  • Theory
    Entunassa • 07/02/2020 at 07:54 • 0 comments
    Contribution #1 by Entunassa:
    I´m not very experienced into MPP trackers and not into programming also. We have to check different concepts or existing schematics for what we can use.
    https://www.researchgate.net/profile/Abdelhalim_Zekry/publication/290436504_Enhancing_the_design_of_battery_charging_controllers_for_photovoltaic_systems/links/5baa2d1645851574f7e441f8/Enhancing-the-design-of-battery-charging-controllers-for-photovoltaic-systems.pdf
    (this is one of the finds from "the internet"...)
    I suggest a modern software approach that yet fits in a tiny PIC or ATMEL; my hope is to find a tiny program which maybe can be translated to the 4004 system without pushing its boundaries.
    https://ww1.microchip.com/downloads/en/appnotes/00001521a.pdf
    It could help not to re-invent the wheel, but rather have the focus on the conversion to the 4004.
  • Hardware Environment
    Entunassa • 07/02/2020 at 07:39 • 0 comments
    Let´s face some ideas about the hardware. What do we need, what has to be covered?
    • a minimal solution is preferred;
    • using vintage parts (?);
    • converting an existing schematic (?)
    • power saving by switching-off electrical parts when not needed (?)
    • simple status indicator
    • ... (to be continued)
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Entunassa wrote 07/08/2020 at 17:28 • point
Jan, just let me know how you want to proceed and what your preferences are in this project. Greetings Jan (my name also :-)
CC2652RB, multiprotocol 2.4 GHz development stick, breakout or ZigBee coordinator and OpenThread border router
Project Owner Contributor
CC2652 - ZigBee coordinator & OpenThread router
SaschaSascha
Part 3 of the aforementioned project
Part 3 - 20mm ammo can ATX casemod
JakeJake
Using a HP T730 Thin Client as a quick and dirty firewall
Quick PFSense/OpenSense Firewall using thin client
cprossucprossu
Instrument-tuner on a badge for DEF CON 28 in 2020.
DC28 Jam Con Badge
RobbRobb
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "Solar MPP tracker", please tell us the reason.
Send message
Remove Member
