Tests of MAX98357A module
A project log for Perfect I2S audio DAC for ESP8266
I'm looking for perfect audio DAC for ESP8266.
andrey.malyshenkoandrey.malyshenko 07/14/2020 at 19:460 Comments
First to test is popular ready-to-use module based on MAX98357A chip.
Data format: I2S, mono output
Ouput: 3W D-class amp, low-impedance
Price: ~€4 per unit, or ~€7 per stage
Here is the setup and test circuit
On the output there will be sine tones on following frequiencies: 1K, 2K, 10K, 20K
Unfortunately i only have toy oscilloscope, therefore results will be eye measured:)
Amp will be loaded with 10 Ohm resistor and measurment will be done on the output and after first-order low-pass filter set on ~30K cutoff frequency, which would be standard in every DAC's ouput.
Test signal is mono wav file generated by esp8266 module using ESP8266Audio library, industry standard 44.1Khz sampling rate.
1KHz before filter, after filter
2KHz before filter, after filter
10KHz before filter, after filter
20KHz before filter, after filter
As you can see, output is quite noisy, this is what you expect from low performance D-class amp, even after RC filter line is loaded with noise. Probably you can eliminate it more by adding more ouput filter stages, but since it is already beyond normal out-of-the-box usage of module, i will not do it for now.
More importantly alteady at 10Khz signal level is ~3V peak-to-peak, compared to ~4V at 1KHz. This is significant drop, most certainly hearable.
20Khz performance is beyond words. Signal is simply vanished.
