This project builds a wearable, cloud connected camera. This is useful in situations where you want a record of what the camera sees stored in the cloud as quickly as possible. Make sure you use this in compliance will all applicable laws and privacy considerations.
This is video only, no audio. If you want to add audio, then I'd love a PR to add, or wait till I get a chance to add it.
This app requires a Raspberry Pi connected to a Raspberry Pi Camera and WiFi. It continuously records short videos from the camera (by default 10 seconds in length), and uploads these to Azure blob storage. The ideal setup is a Pi Zero W due to its small size and low power requirements, tethered to a mobile phone or hotspot for internet access.
This uses a cloud service to store the videos, and therefor may incur a cost. If you have a free trial account, you can get $200 for the first 30 days which should more than cover the cost. Check out the Blob storage pricing guide for more information on the cost of the service used.
This method allow resiliency - if WiFi connection is lost the upload will keep retrying. If the device is damaged then everything already uploaded will be secure. Files are stored on the SD card and only deleted after successfully being uploaded, so if there is no internet connection, files can be grabbed off the SD card.
This also allows audit trails - each short video is named with the current timestamp, and Blob storage stores the time the file was uploaded.
The code for the project also includes a utility to download all the blobs and concatenate them into a single video file.
You can find all the code on GitHub at https://github.com/jimbobbennett/pi-hat-cam.
What's required
To make this, you will need:
Set up the application
Before you can run the application, you need an Azure subscription and a storage account.
Set up your Azure Subscription
Set up the storage account
An Azure storage account is a general purpose account to store data as files, queues, tables or blobs. In this app, each short video is stored as a blob in the storage account.
To create a storage account:
  1. Head to ms.portal.azure.com/#create/Microsoft.StorageAccount-ARM to go straight to the create a new storage resource blade
  2. Sign in with your Azure account if necessary
  3. Select your Azure subscription
  4. For the Resource group, select Create new. Name the resource group hatcam then select OK
    Creating a new resource group
  5. Name the storage account. This name has to be globally unique across all storage accounts in Azure - this is because this name becomes part of the URL that can be used to access it. Pick a name that makes sense to you with something unique like your name, the date, etc.
    This name can only contain lowercase numbers and letters
  6. For the location, select the one closest to where you will be using the camera.
    If you want to see the locations of the regions, check out the map in the Azure global infrastructure guide.
  7. Leave the rest of the values as the defaults
    The create storage form filled in
  8. Select Review + create
  9. The storage account settings will be validated. Once done, select Create.
The deployment will begin. You will be notified when it's complete.
Get the connection string
To connect to the storage account, you will need a connection string. To get this:
  1. Open the storage account in the Azure portal. You can do this by selecting Go to resource from the notification that pops up with the storage account is deployed.
    The deployment notification
  2. From the side bar, select Settings -> Access keys
    The access keys menu
  3. Select the Copy to clipboard button next to the Connection string under either Key 1 or Key 2. It doesn't matter which one.
    The connection string
  4. Store this connection string somewhere. You'll need it to configure your Pi code.
Deploy the code
Once you have the storage account, it's time to deploy the code from https://github.com/jimbobbennett/pi-hat-cam. The code is fully documented and commented, so check out the app.py file to see how it all works.
Configure the Pi
You will need to be running the latest Raspberry Pi OS on your Pi Zero W. To make the camera faster to launch, you should install Raspberry Pi OS Lite.
To do this, use the Raspberry Pi imager. When you choose the OS, select Raspberry Pi OS (other), then select Raspberry Pi OS Lite (32 bit).
Once your SD card is ready, configure the Pi for headless access by following the steps in this headless setup guide. Work through the steps up to the Remote desktop section - you don't need to follow this section as it contains instructions when using the full Raspberry Pi OS, not the Lite version you are using here.
Deploy the Python code
The Python code you need is in this repo in the pi-app folder.
  1. SSH into your Pi
  2. Install git, Pip and Python virtual environments using the following command:
    sudo apt install git
    sudo apt install python3-pip
    sudo apt install python3-venv
  3. Clone this repo:
    git clone git@github.com:jimbobbennett/pi-hat-cam.git
  4. Navigate to the folder containing the code
    cd pi-hat-cam/pi-app
  5. Create a Python Virtual Environment:
    python3 -m venv .venv
  6. Activate the virtual environment:
    source ./.venv/bin/activate
  7. Install the Pip packages
    pip install -r requirements.txt
Configure the app
Once the code is deployed, you'll need to configure the app to connect to your Azure storage account.
The code uses the dotenv package to read environment variables from a .env file. You will need to create this file and add the Azure storage connection string that you copied earlier to it.
  1. Create the file and open it for editing in nano:
    nano .env
  2. Add the following entry:
    BLOB_CONNECTION_STRING=<connection_string>
    Replace <connection_string> with the connection string you copied earlier.
  3. Close the file by pressing ctrl+X. You will be prompted to save the file, so select yes and press enter to select the .env filename.
There are other optional parameters you can add to this file to configure things like the video resolution or quality. Check out the <a target="_blank" rel="noopener noreferrer" href="http://app.py">app.py</a> code for more details.
Test the app
Before you use this in the wild, you should test the app.
  1. Connect the camera to the Pi
  2. Run the Pi code with this command:
    python app.py
  3. The app will start up and begin recording, uploading videos to blob storage once they are recorded. You should see something like this in the output:
    (.venv) pi@hat-cam:~/pi-hat-cam $ python app.py
    Checking container videos
    Setting camera resolution to 1280 , 720
    Starting queue worker
    Recording ./videos/2020-07-08 07:42:51.h264
    Queuing ./videos/2020-07-08 07:42:51.h264
    Recording ./videos/2020-07-08 07:43:01.h264
    Uploading ./videos/2020-07-08 07:42:51.h264 to 2020-07-08 07:42:51.h264
    Deleting ./videos/2020-07-08 07:42:51.h264
  4. Stop the app using ctrl+c
  5. Head to the storage account in the Azure portal.
  6. Select Storage Explorer from the side menu
    The storage explorer menu
  7. You should see the blob files that were uploaded listed here
    The files listed in the storage explorer
You can download these files by selecting one and selecting Download. The downloaded file can be opened in an app like VLC.
Configure the app to run on startup
Once the app is deployed, it can be run manually from the command line. It's better, however, if it is started when the Pi is booted - that way it is running automatically not long after the Pi is connected to power.
You can do this by adding an entry to the crontab. Cron is a tool that runs code at certain times, and can be configured to run the Pi code when the Pi is rebooted.
  1. Run the following code to configure the CronTab:
    sudo crontab -l > cron.tmp
    echo "@reboot sleep 30 && cd /home/pi/pi-hat-cam/pi-app && /home/pi/pi-hat-cam/pi-app/.venv/bin/python /home/pi/pi-hat-cam/pi-app/app.py" >> cron.tmp
    sudo crontab cron.tmp
    rm cron.tmp
This code writes a new entry that is run on reboot. First it sleeps for 30 seconds to ensure the Pi is fully running and connected to the internet, then it launches the <a target="_blank" rel="noopener noreferrer" href="http://app.py">app.py</a> file using the Python binary in the virtual environment.
Test this out by rebooting the Pi. You should see video files appear in the Storage Explorer in the Azure portal. Power the Pi off when done.
Download the video
By creating short videos it helps ensure the videos are uploaded, but this is not the best for watching later. It would be easier if there was a way to reassemble the video. The video_downloader.py file in the downloader folder has code to do this.
This file needs a .env file set up the same as the main app, with the BLOB_CONNECTION_STRING value set. There are other values you can configure from the default, and this are listed in the code.
Ideally you should run this code on a device that is not the Pi, so that you can view the video. You will need Python installed.
  1. From the folder the video_downloader.py is in, create a Python Virtual Environment:
    On Windows, use:
    python -m venv .venv
  2. Activate the virtual environment:
  3. Install the Pip packages
  4. Create a file called .env in your favorite text editor, such as Visual Studio Code
  5. Add the following entry:
  6. Run the code:
    python video_downloader.py
This will download all the blobs, concatenating them into a single file called downloaded_video.h264. You can then view ths file in an app like VLC.
The blobs are not deleted when you download them. You will need to manually delete them from the storage resource once you are finished with them.
Create the wearable
There's so many different pieces of clothing you could attach this to. In this guide I'm going to focus on a cap.
You will need:
All the parts - cap, gaffer tape, scissors, pi, camera
Mount the camera
  1. Make a small hole in the front of the cap - big enough for the camera lens to fit through
  2. Place the camera inside the hat and push the lens through the hole. It might be easier to detach the camera from the board to pass it through the hole.
    The camera poking through a hole
  3. Fix the camera in place on the front of the hat with double-sided mounting tape. You can use fabric glue, but be careful not to get any on the lens. This also reduces you ability to easily re-use the camera in a different make.
  4. Fix the camera circuit board in place inside the cap using gaffer tape
    The camera module in the hatThe camera module taped in teh hat
  5. Fix the camera ribbon cable to the inside of the cap, right through to the hole at the back. Use gaffer tape or sew it in place.
    Ribbon cable taped into the hat
  6. Mount the Raspberry Pi Zero W to the back of the cap, attaching the camera ribbon cable. Use double sided mounting tape, gaffer tape or sew it in place, whatever works. The USB sockets should point downwards.
    The pi mounted to a hat
  7. Test out the connections - power the Pi over USB and make sure videos are being uploaded. Also test out the fit and camera position, adjust it as necessary using tape or fabric.
Jim in the hat cam
Use the camera
To use the camera, first it needs to be tethered to your phone or a WiFi hotspot to upload the videos. To tether:
  1. Connect to the Pi over SSH
  2. Start your WiFi hotspot, or enable tethering on your phone
  3. From your Pi, launch the configuration tool:
    sudo raspi-config
  4. Select 2 Network options
    The pi config main menu
  5. Select N2 Wireless LAN
    The network menu
  6. Enter the SSID and Password of your hotspot
  7. Select Finish
  8. When asked to reboot, select Yes
When the Pi reboots, it will connect to your hotspot or phone.
Power off the camera until you are ready to use it.
Once you are ready to use it, connect the power and it will start recording as soon as it has booted up.
Here's the camera in action browsing the code repo:
A video of this repo being browsed on a computer
