Purchased from Craigslist out of a barn, not in horrible shape, but a little rusty and non-functional.
I have since cleaned up all surfaces, and applied oil.
What is is: A Bridgeport Series I vertical mill (9x42" table) with a three-axis Anilam Crusader II CNC controller. Originally, the main components are:
  • Servo "amplifier" box, made up of the main power supply and three servo amplifiers
  • Control box, which is the Crusader II, including its own power supply (which is bad)
  • Per-axis DC brushed motor, originally with a tacogenerator for RPM feedback
  • Per-axis Acu-Rite 10 um glass scales, with quadrature output
  • Not specifically part of the CNC package, but a three phase AC induction motor for the spindle
This project is to remove the Crusader II, and upgrade it:
  • Main control to be Grbl, or similar, to produce step/dir pulses
  • Servo drives to be Machdrives' BRA controllers, which consume step/dir pulses
  • Spindle drive to be a Toshiba VFS7S VFD
  • Keeping the glass scales and servo motors
  • Rotary encoders to replace the analog tach in the servo motors
