PCB Design - Sponsored by PCBWay
A project log for USB Component Tester
Thumb-drive sized Universal Component Tester
akshay-bawejaAkshay Baweja 07/23/2020 at 22:190 Comments
The PCB is designed to be the size of a thumb drive with male USB-A connector. The 3 Test Pads are exposed for soldering the test leds onto them. The dimensions of PCB are approximately 34mm x 17mm.
