CPU control: don't decode, just execute
A project log for SIFP - Single Instruction Format Processor
A super-scalar, reduced instruction set processor where microcode and machine code are the same thing!
zpekiczpekic 12/10/2023 at 23:330 Comments
Classic CPUs execute instructions by going through a predetermined set of machine states. With SIFP16's unique design, these machine states are at the same time proper CPU instructions. This means, that regardless of the program, SIFP-16 always only executes 14 CPU instructions and goes over 14 possible states.
In absence of special execution conditions (HOLD, TRACE, INTERRUPT), only 2 instructions / states are executed:
  1. FETCH:
    1. CPU executes following instruction: r_p_M_IMM & r_a_NOA & r_x_NOX & r_y_NOY & r_s_NOS (this will generate VMA and RnW both high)
    2. FETCH signal is asserted on the bus (useful for debugging)
    3. Data bus input is loaded into 16-bit reg_i (instruction register)
  2. EXECUTE:
    1. CPU executes whatever is in reg_i
    2. go back to FETCH
The simplest control unit implementation could simply be a flip-flop, driving a 2->1 MUX, one input hard coded to fetch, other connected to reg_i.
But to make a full-fledge processor, handling additional states makes it a bit more complex:
Notes for the diagram above:
1. Machine instruction is "NOP", but instead contents of reg_i is executed, loaded in step 0
2. If TRCE (trace condition) is asserted, all processor registers are output on the data bus, and their index on address bus. This is useful to inspect state of each register after each instruction
3. LDP loads P (program counter) from data bus, but instead of VMA (valid memory address), INTA (interrupt acknowledge) signal is asserted to indicate that an interrupt vector should be presented to the data bus.
4. FETCH cycle is started after RESET, and all other states eventually lead here
5. State / instruction 15 is a "dead loop" as long as external circuit holds HOLD high. During that time HOLDA output is high and bus is tri-state ("Z" in VHDL)
Following control signals determine the flow:
[0003]CLC:  r_a = STA, r_s = M[PUSH];
MW,FFFD DEAD
RV,  F= 0010
RV,  A= DEAD
RV,  X= BEEF
RV,  Y= BEEF
RV,  S= FFFD
RV,  P= 0073
[0004]  r_p = M[IMM], r_a = LDA;
MR,0074 0000
RV,  F= 0018
RV,  A= 0000
RV,  X= BEEF
RV,  Y= BEEF
RV,  S= FFFD
RV,  P= 0075
[0006]ACSet:  SLC;
RV,  F= 0018
RV,  A= 0000
RV,  X= BEEF
RV,  Y= BEEF
RV,  S= FFFD
RV,  P= 0076
[0007]  r_a = LDA, r_s = M[POP];
MR,FFFD DEAD
RV,  F= 0000
RV,  A= DEAD
RV,  X= BEEF
RV,  Y= BEEF
RV,  S= FFFE
RV,  P= 0077
The actual implementation of control unit is centered around a ROM of 16 instructions (2 are not used). The instruction width is 32 bits:
-- instruction word
signal cpu_instruction: std_logic_vector(31 downto 0);
alias cpu_if:      std_logic_vector(1 downto 0) is cpu_instruction(31 downto 30); -- select condition ("IF")
alias cpu_then:  std_logic_vector(3 downto 0) is cpu_instruction(29 downto 26); -- next state if condition true ("THEN")
alias cpu_else:  std_logic_vector(3 downto 0) is cpu_instruction(25 downto 22); -- next state if condition false ("ELSE")
alias cpu_hlda:  std_logic is cpu_instruction(21); -- 0: bus hold (tri-state) machine cycle
alias cpu_inta:  std_logic is cpu_instruction(20); -- 0: load interrupt vector
alias cpu_done:  std_logic is cpu_instruction(19); -- 1: last machine cycle in instruction
alias cpu_bctrl: std_logic is cpu_instruction(18); -- 0: alternative bus control (ABUS = register address; VMA, PnD, RnW = '0')
alias cpu_irexe: std_logic is cpu_instruction(17); -- 1: execute from instruction register
alias cpu_fetch: std_logic is cpu_instruction(16); -- 1: fetch
-- format of lower 16-bit is exactly the same like the instructions stored in external memory!
alias cpu_i: std_logic_vector(15 downto 0) is cpu_instruction(15 downto 0);
Note:
-- CPU program
-- CPU always executes only these instructions continously
-- except at step 1 when the instruction executed is coming from instruction register
-- which was loaded from external memory
-- this works because the lower 16 bits of the instructions in this program are same as
-- instruction format stored in external memory
constant cpu_program: mem16x32 := (
    -- basic loop (fetch / execute)
    -- 0: fetch, then hold or execute
    if_hold & X"F" & X"1" & "000101" & c_FETCH,
    -- 1: execute, then continue (fetch next instruction) or special path
    if_cont & X"0" & X"2" & "001110" & c_NOP,
    -- trace routine outputs register index on A bus and value on D bus
    -- 2: output F(flags), if trace then output other regs else push regs (interrupt)
    if_trce & X"3" & X"8" & "000000" & c_FTOS,
    -- 3: output A, continue
    if_intr & X"4" & X"4" & "000000" & r_p_NOP & r_a_A     & r_x_NOX & r_y_NOY & r_s_NOS,
    -- 4: output X, continue
    if_intr & X"5" & X"5" & "000000" & r_p_NOP & r_a_NOA & r_x_X     & r_y_NOY & r_s_NOS,
    -- 5: output Y, continue
    if_intr & X"6" & X"6" & "000000" & r_p_NOP & r_a_NOA & r_x_NOX & r_y_Y      & r_s_NOS,
    -- 6: output S, continue
    if_intr & X"7" & X"7" & "000000" & r_p_NOP & r_a_NOA & r_x_NOX & r_y_NOY & r_s_S,
    -- 7: output P, if interrupt then push regs else fetch (new instruction)
    if_intr & X"8" & X"0" & "001000" & r_p_STP & r_a_NOA & r_x_NOX & r_y_NOY & r_s_NOS,
    -- interrupt routine pushes P and F on the stack, disables tracing and interrupts, and then load the int vector
    -- 8: push P, continue
    if_cont & X"9" & X"9" & "000100" & c_PUSHP,
    -- 9: push F, continue
    if_cont & X"A" & X"A" & "000100" & c_PUSHF,
    -- A: turn trace flag off, continue
    if_cont & X"B" & X"B" & "000100" & c_INTOFF,
    -- B: turn interrupt enable off, continue
    if_cont & X"C" & X"C" & "000100" & c_TRACEOFF,
    -- C: load intrrupt vector, then fetch next instruction
    if_cont & X"0" & X"0" & "010100" & c_LDP,
    -- unused, reserved for future use
    -- D: unreachable nop
    if_cont & X"0" & X"0" & "000100" & c_NOP,
    -- E: unreachable nop
    -- bus hold routine
    -- F: hold (tri-state) until HOLD signal detected low, otherwise execute
    if_hold & X"F" & X"1" & "100000" & c_NOP
