In the process of moving the shift keys around, I have simplified the code somewhat, made it better at handling some corner cases, and fixed some bugs. Just in case someone wants to make a similar build, I'm putting it below. In the future it might grow into a proper CircuitPython library perhaps – then it will get its own repository.
import board
import digitalio
import usb_hid
import time
COLS = (board.A6, board.A1, board.A4, board.A3, board.D6,
board.SCL, board.SDA, board.D12, board.D10, board.D13)
ROWS = (board.MOSI, board.AREF, board.D11, board.D5)
LEDS = (board.A2, board.A5, board.TX, board.RX, board.D9)
class Keyboard:
def __init__(self, matrix, cols=COLS, rows=ROWS):
self.matrix = matrix
self.cols = [digitalio.DigitalInOut(pin) for pin in cols]
self.rows = [digitalio.DigitalInOut(pin) for pin in rows]
for col in self.cols:
col.switch_to_output(value=0)
for row in self.rows:
row.switch_to_input(pull=digitalio.Pull.DOWN)
for self.device in usb_hid.devices:
if self.device.usage == 0x06 and self.device.usage_page == 0x01:
break
else:
raise RuntimeError("no HID keyboard device")
self.debounce = bytearray(len(cols))
self.last_state = bytearray(len(cols))
self.current_layer = 0
self.pressed_keys = set()
self.last_held = 0
self.release_next = 0
def scan(self):
if self.release_next:
try:
self.pressed_keys.remove(self.release_next)
except KeyError:
pass
for x, col in enumerate(self.cols):
col.value = 1
debounce_bits = 0
for y, row in enumerate(self.rows):
state = row.value
debounce_bits |= state << y
if state != bool(self.debounce[x] & (1 << y)):
continue
last_state = bool(self.last_state[x] & (1 << y))
if state:
self.last_state[x] |= 1 << y
else:
self.last_state[x] &= ~(1 << y)
if state == last_state:
continue
if state:
self.press(x, y)
else:
self.release(x, y)
col.value = 0
self.debounce[x] = debounce_bits
def press(self, x, y):
if self.last_held:
self.last_held = 0
code = self.matrix[self.current_layer][y][x]
if code & 0xff00:
if (code & 0xff) != 0:
self.last_held = code
if code & 0xff00 == 0x0800:
self.current_layer = 1
else:
self.pressed_keys.add(code & 0xff00)
return
self.pressed_keys.add(code)
def release_all(self, x, y):
for layer in 0, 1:
for mask in 0xffff, 0xff00, 0x00ff:
code = self.matrix[layer][y][x] & mask
try:
self.pressed_keys.remove(code)
except KeyError:
pass
def release(self, x, y):
for layer in 0, 1:
if self.last_held == code:
self.release_all(x, y)
self.pressed_keys.add(code & 0xff)
self.release_next = code & 0xff
self.last_held = 0
return
def send_report(self, pressed_keys):
report = bytearray(8)
report_mod_keys = memoryview(report)[0:1]
report_no_mod_keys = memoryview(report)[2:]
keys = 0
for code in pressed_keys:
if code == 0:
continue
elif code == 0x0800:
continue
elif code & 0xff00 and code & 0xff == 0:
modifier = (code >> 8) - 1
report_mod_keys[0] |= 1 << modifier
elif keys < 6:
report_no_mod_keys[keys] = code
keys += 1
self.device.send_report(report)
def run(self):
last_pressed_keys = set()
while True:
self.scan()
if self.pressed_keys != last_pressed_keys:
self.send_report(self.pressed_keys)
last_pressed_keys = set(self.pressed_keys)
time.sleep(0.01)
deʃhipu
