IR
A project log for Projector Control
Adding WiFi to a 15-year-old LCD projector
andy-castilleAndy Castille 08/09/2020 at 03:082 Comments
By the end of the previous post, I had decided that the reliability of a direct serial line to the projector wasn’t worth the cost of a MAX232 chip over some IR diodes, so I ordered the latter. I anticipated the process of extracting the IR codes from the remote and replicating them would be difficult, lengthy, and finnicky, but it was actually pretty easy.
Hardware
My final working build uses these components:
For recording the IR codes from the remote, I used a receiver diode connected to an Arduino Uno with the following configuration:
Receiver DiodeArduino
+ Cathode
5V out
SignalPin 11
− AnodeGND
Then I flashed the IRrecvDump example from Ken Shirriff’s IRremote library to the Arduino Uno, pointed my projector’s old remote at the receiver, and pressed every single button, noting the hex code output to the serial console. It also printed “Decoded NEC” each time, indicating Sanyo chose to use NEC’s IR protocol, which is important to know when sending these codes to the projector later.
I ended up with the following code table:
Remote buttonCode
Power0xCC0000FF
Computer input
0xCC001CE3
Video input
0xCC00A05F
Menu0xCC0038C7
Left arrow
0xCC007887
Right arrow
0xCC00B847
Up arrow
0xCC0031CE
Down arrow
0xCC00B14E
Select/OK/enter0xCC00F00F
Digital zoom up
0xCC00807F
Digital zoom down
0xCC0040BF
Page up
0xCC009A65
Page down
0xCC005AA5
Keystone0xCC00DA25
No show
0xCC00D12E
Auto PC adjust
0xCC00916E
Power-off timer
0xCC0051AE
Image settings
0xCC0030CF
Freeze0xCC00C23D
Mute0xCC00D02F
And any time I held a button, it sent 0xFFFFFFFF. I saw an “NEC repeat code” referenced in the IRremote documentation, so I’m assuming that’s what it is. I included it in my final project code, but it is never actually sent, and I have not needed it so far.
When I was done recording the codes, I assembled a second breadboard for “production” use where I had just a Particle Photon, an IR emitter diode, and a resistor between A5 on the board and the diode to protect the diode. I then strapped this to the side of my projector so the emitter sat in front of the projector’s IR receiver.
Backend
Speaking of project code, I have uploaded the full code I flashed to the Particle Photon (with the MQTT server and credentials emptied, of course) as a project file.
It hosts a web interface and API for manual control over the network, but it also connects to an MQTT server for control by home automation software.
It requires the following libraries:
Frontend
For fun, I designed the web interface it hosts to look exactly like the original remote:
Hopefully, your browser has rendered the HTML document beautifully above. The HTML document behind this isn’t as pretty as the result, (especially when represented as a string in the C++ source code) but you can download it as a formatted HTML file from the project files if you wish.
Clicking a button on that preview will not do anything, but when hosted from the board, it will make an HTTP POST request to the board that contains the form data key button and a numeric value. The getCommand function parses this value and maps it to an IR code for transmitting to the projector.
Sure, a web UI is fun, but it’s not very convenient. Navigating to the page in a browser isn’t as fast as picking up the remote off the table. This is where the MQTT functionality comes in.
In Home Assistant, which is connected to the same MQTT broker as the projector control, I created two scripts: one to turn the projector on by “pressing” the power button, and the other to turn it off by “pressing” the power button twice (once to open the “are you sure?” dialog, and again to confirm).
script:
  projector_on:
    alias: Projector on
    icon: mdi:projector
    mode: single
    sequence:
    - service: mqtt.publish
      data:
        topic: projector/cmd
        payload: 1
  projector_off:
    alias: Projector off
    icon: mdi:projector
    mode: single
    sequence:
      data:
        payload: 1
      data:
        payload: 1
Note here that I am just sending raw MQTT commands to the broker for the topic listened to by the board code (projector/cmd) with the command number (1) that maps to the power button. Once for on, twice for off.
Okay, now I can control it with a different web interface (Home Assistant). It’s still not that convenient. That’s where Google Assistant helps out. One more addition to my Home Assistant configuration:
google_assistant:
  script.projector_on:
    expose: true
  script.projector_off:
    expose: true
That makes the projector on and off scripts show up in my Google Home app, but I then created a routine for each action and added a step to call the correct “scene”. Now I can say, “Okay Google, projector on” and it will turn on the projector (and the lamp so I can turn off the overhead light).
Areas for improvement
If anyone has the same projector and wants to use my existing code mapping, make sure the remote setting in the projector menu is set to "Code 1". If it is set to "Code 2", your IR codes will all be different.
Hopefully this helps anyone looking to automate a device with IR. Questions? Comments? Need help? Let me know below!
Arnaud Mondit wrote 11/14/2020 at 14:35 point
Actually the codes are consecutive, it is NEC format with device 51 (CC with LSB first) and 05 is command 160 LSB first and FA is inversed 160
You can find many command numbers there: (you have to compute the hex value though) http://www.remotecentral.com/cgi-bin/forums/viewpost.cgi?728253
Arnaud Mondit wrote 11/14/2020 at 11:09 point
Power on: 0xCC0005FA
Compulsory power off (without warning): 0xCC00857A
