ESP32 - RS485 - 4 input, 4 output
Including 4 Universal input (0-10 VDC , 10 kΩ Thermistor, 4-20 mA, Dry Contact), 4 Relay output (250VAC, 5A), RS485, I2C
Starting from
$69.00
daohoa has 1 orders / 0 reviews
Ships from Vietnam
Including 4 Universal input (0-10 VDC , 10 kΩ Thermistor, 4-20 mA, Dry Contact (using 10 kΩ Thermistor jumper setting), 4 Relay output (250VAC, 5A), RS485, I2C
Inputs
4 Universal  input
  0-10 VDC (using the 10V jumper and ON jumper setting)
  10 kΩ Thermistor (using the 10 kΩ Thermistor jumper and OFF jumper setting)
  4-20 mA (using the 4-20mA jumper and ON jumper setting)
Outputs
Power
9-24VAC / DC
Communications Ports
RS-485 supporting:: Modbus up to 115200 bps
ESP32 WiFi, Bluetooth
If you are interested can contact me via email daovanhoa12@gmail.com or my skype id: Đào Hoa (live:daovanhoa12), facebook  https://www.facebook.com/daovanhoa12
View all 2 project logs
