Altoids Tins are neat.
A project log for Simple FM Repeater
A simple home brew FM ham radio repeater.
kd9kckKD9KCK 12/15/2020 at 03:570 Comments
I just finished re-working the boards schematic and pcb layout.
Here is the final product.
It will fit inside an altoid's tin. It requires 3.3 volts to run still. I think I might make a slight modification to add voltage regulation  and also I still need to get the interrupt's working on the board I have before I decide to do a spin of this board.  (As it might be a missing pull up or something.)
