Z
A project log for Minamil: a minimal CNC mill. And friends.
Each axis: ̶$̶5̶ ̶$̶8̶ $10 motor+lead screw, 3x LM6UU, 3x 6mm x 100mm rod, 1/8in hardboard, PC case screws
Paul McClayPaul McClay 08/23/2020 at 03:060 Comments
Using one of the first lightly built test sliders and some close-enough wood scraps (no saw handy), cobbled a Z axis just to see if this has a chance of working. It does appear to have a chance.
Here exercising 5 cm travel in each axis:
With optimistic anticipatory debris screen because testing the XY table started to get a little messy.
My faux-Dremel weighed 510gf. A 500ml bottle of water weighed 510gf. Presumably 500ml beverage bottles are easy to find so makes sense to design for a user-provided counter weight.
Unloaded backlash/hysteresis is well under 50μm for all axis. The SM1545 motors have an axial spring to preload the bearings, and that compresses a bit when loaded in one direction. The laser cut parts have untested pilot holes for screws to limit the axial spring play.
