Parallel Finishing
A project log for Minamil: a minimal CNC mill. And friends.
Each axis: $̶5̶$8 motor+lead screw, 3x LM6UU, 3x 6mm x 100mm rod, 1/8in hardboard, PC case screws
Paul McClayPaul McClay 08/24/2020 at 18:110 Comments
A couple logs back concluded with:
Next up: is Z hysteresis small enough to run paths with varying Z vs a succession of descending waterline paths?
(i.e. parallel finishing)
Yes.
Parallel Finishing Works
sufficiently small Z backlash/hysteresis allows Z-varying tool paths
The second pocket has other issues, but this isn't about that.
