Comment on copper wires
A project log for Retrofitting USB-C on any 3D Printer
How-to tutorial showing step by step how to change the USB connector on any 3D printer
zedd-hiroZedd Hiro 08/28/2020 at 16:011 Comment
 I know it's not the tidiest way of doing this conversion but I have looked in this matter extensively and I did find other , more "elegant" solution for the transplant.
Please refer to the following video to see what was my other alternative and the reason I didn't do it.
In the comments of the video you will find technical details about the parts you will need for the alternative transplant solution.
Chad Buchanan wrote 07/26/2021 at 06:00 point
In this blog post we are going to go over copper wires and the different types of wire, their strengths, weaknesses, and how they compare. Copper is a type of metal that has many uses. It can be used for top dissertation writing services wiring in electronics as well as other things like plumbing or roofing. In this blogpost we will go over some basics about copper cables such as what they are made of and why it's important to know when buying them.
