8/27/2020 Improve motor
A project log for solar powered boat
low-cost methods to power boats from solar power
sean-depagniersean d'epagnier 08/29/2020 at 19:000 Comments
  I drilled a hole through the shaft and put a stainless screw through the shaft and pulley, hopefully this will stop it from slipping.    I cannot test for a few days because of high winds.  I would normally only sail in these conditions, after all, the boat can sail much faster than it will ever go on solar power.
