The first idea was to use MAX1719 display driver. But due to late delivery of my parts order, I have tested with inhand TM1637 4 Digits 7 segment display driver module. Quick google search and after test, temperature is shown successfully in Deg C.
Lib use: https://github.com/avishorp/TM1637
Connection:
Vcc - 3.3V
GND - GNE
CLK - ESP32 18
DATA - ESP32 19
# Note : Need to find out a way to enable single dot for decimal point. (or) MAX1719 with 8x8 dot matrix display?
