The functional Prototype works ! The mechanical construction and the wiring a really poor at the moment. But even this low level machine gives acceptable results. Next step will be some testing if a speed control is needed and if a Arduino 'Motheroboard' is used instead of single controller
![](https://cdn.hackaday.io/images/7162421599115842028.jpg)
![](https://cdn.hackaday.io/images/5661971599115842243.jpg)
![](https://cdn.hackaday.io/images/9867771599115844441.jpg)
![](https://cdn.hackaday.io/images/5743551599115845136.jpg)
