Test of the functional Prototype
A project log for Xtruder - A Desktop Filament Extruder
The machine uses an extrusion screw to make filament, yarn and small beams out of plastic pellets and flakes
devlabnrwDevLab.nrw 09/03/2020 at 06:520 Comments
The functional Prototype works ! The mechanical construction and the wiring a really poor at the moment. But even this low level machine gives acceptable results. Next step will be some testing if a speed control is needed and if a Arduino 'Motheroboard' is used instead of single controller
