The rectangles code wasn't working correctly on the EP4 FPGA card. Luckily, I found the problem relatively easily. Required setting the rows and columns for the SDRAM part that is used on the card. In the C4BoardTopLevel file.
tg68tst : entity work.VirtualToplevel generic map ( -- W9825C6KH-6 Winbond 4M X 4 Banks x 16 bits SDRAM -- 13 rows, 9 columns sdram_rows => 13, sdram_cols => 9,
The same fix needs to be done for the Cyclone V card since it used the same SDRAM part.
