After seeing ads for the FreeWrite and going so far as to buy an AlphaSmart Neo2, I decided that this a problem spaced under-served by Linux. Sure, there is the E-Ink DIY one driven by a Pi, but it's not really practical: <a target="_blank" rel="noopener noreferrer" href="https://hackaday.com/2018/10/20/e-ink-typewriter-is-refreshingly-slow/">https://hackaday.com/2018/10/20/e-ink-typewriter-is-refreshingly-slow/</a>. This project is about making a Linux software solution based on more conventional hardware and making use of kiosk tools for Linux. This also lets me satisfy other itches, like adding calculator functionality via SageMath or circuit simulator functionality via Falstad.
Files
launcher.fish
Fish shell script to launch programs with a menu & navigate the filesystem in the style of the old DOS PowerMenu-style launchers
I've flip-flopped again on the software design, and decided to go for a more hacker-ey approach that uses a tiling window manager + terminal window instead of a browser in kiosk mode. I'm using the following software:
Xubuntu 18.04
Xmonad window manager
XFCE4 terminal
Vim/Nano text editors
Feh image browser
Zathura PDF viewer
W3M browser
Ranger/NNN file managers
HTOP system viewer
NCDU disk space viewer
I discovered it's pretty easy to hack together a menu-based interface with Fish shell script, though it's a bit janky. Better options are wiretail (easier, more portable)/dialog (more verbose, more flexible) which allow for decent-looking GUIs in shell scripts.
Off-topic, I also learned about Zenity which is the GTK equivalent. It has Python bindings and seems like a nicer alternative to PyQT (pretty but tedious to code up) and PySimpleGUI (fast to code but hideous as the library tries to look like a 90s WinForms enterprise app).
After a bit of research, there really isn't much in the way of distraction-free writing apps that work in a browser. The most popular (Typora, commercial and FocusWriter, FOSS) are native. Probably this is an entirely reasonable thing. Currently I'm looking at notes apps. Standard Notes seems nicest, but it's a bit of a pain to get running. Reasonable alternatives are Trillium, Wiki.js, BookStack, WriteFreely and the various NextCloud notes add-ons.
Currently the project is based on an i3 Intel NUC running Xubuntu + FocusWriter. I have a couple of decisions to make:
1. Should I stick with Intel, go to ARM or stay processor-agnostic?
2. Should I use native fullscreen applications or web-based ones running in FIrefox in kiosk mode?
3. How to Sync? Should I support cloud/network storage, USB drives or adding hardware to emulate a keyboard like the AlphaSmart?
Currently (1) doesn't seem to be too important. There are pros and cons either way. Staying on Intel means better availability of pre-prackaged software and the ability to use the majority of Chromebooks. Going to ARM means the ability to use Pis, Pi0's and PineBooks, and is probably a better choice for a hacker project. A cyberdeck version would be pretty sweet.
With (2) the majority of writing applications are written natively so I haven't found any self-hosted browser-based solutions for writing other than https://github.com/writeas/writefreely. However, a Firefox kiosk-based solution means a couple other benefits: I can limit internet access by whitelisting sites rather than removing or disabling networking hardware. This means that I'm not limited to self-hosted solutions and can use ones that are fully or partly cloud-based like https://www.calmlywriter.com/. This also makes it easy to add local web-based capabilities like SageMath/Falstad, or other cloud-based ones like Cocalc/Repl.it/Overleaf. Honestly, having calculator functionality is more interesting to me than just a writing tool (I'm an engineer and frankly not much of a writer).
With (3) supporting cloud/network storage is easiest from the user-interface perspective. Using USB drives means the need to give the user access into the filesystem, complicating UI. And much as I like my AlphaSmart, emulating a keyboard is a slow unreliable and pretty rubbish way of transferring data.
