Voron Switchwire Upgrade - Side Walls Supports
A project log for Voron Switchwire 3D Printer
Voron Switchwire - DarekNorway Build Log
dareknorwayDarekNorway 03/15/2021 at 12:570 Comments
Voron Switchwire Upgrade - Acrylic side walls with additional inside supports
Voron Switchwire Upgrade - Side Walls Supports file to print: acrilic_enclosure_side_walls_support_v2_x2.stl
Voron Switchwire Upgrade - Side Walls Supports file to print:  https://cdn.hackaday.io/files/1748107479071040/acrilic_enclosure_side_walls_support_v2_x2.stl
https://hackaday.io/project/174810/components
